Overview
Roon supports two output mechanisms on Mac OS X: CoreAudio and *ASIO*.
- CoreAudio is Apple's native audio framework.
- ASIO support on Mac is extremely limited--currently the only devices we are aware of are manufactured by exaSound. If you don't have one of these, you will be using CoreAudio.
Both are capable of bit-perfect playback. CoreAudio is a more modern system, with stronger support for convenience features like volume controls and device identification, and ASIO is more bare-bones and minimal.
For an in-depth overview of the Audio Configuration in Roon, check out our [[Audio Setup Basics]] page.
This page is for mac-specific notes and issues.
Help, I'm having Staticky or Unstable playback with Dirac!
Make sure that the following options are enabled:
- Use Exclusive Mode
- Enable Integer Mode
- Use Power-of-2 Buffer Sizes
Recommended Setup for exaSound devices with ASIO drivers
Make sure that the exaSound dashboard is set to "ASIO" mode. If it leaves ASIO mode, or if the dashboard exits, Roon will have difficulty accessing the device. If you have having problems unexpectedly, this is the first thing to check:
Then, in Roon's audio settings, enable the (2ch) version of the driver, even if you have an 8-channel device
Finally, make your setup screens look like this:
Then play some music.
Related Articles
FAQ: Setting Up Roon on MacOS
Roon is a powerful music management and playback platform that works beautifully on macOS. There are a few important things to know before you dive in and this guide will do just that: it will walk you through the essentials for setting up Roon on ...
Fix Missing Audio Devices After a macOS Update in Roon
If your audio devices disappeared from Roon after a macOS update, this article walks you through the steps that can help restore them. Try each section in order. If your devices return, you can stop there. Otherwise, move on to the next section. ...
Audio Setup Basics
Accessing Audio Settings To access audio settings, click the settings cogwheel from the navigation bar, then choose the Audio tab. Inside the Audio tab, you'll be presented with a list of audio output devices, grouped by type, and in some cases, by ...
MUSE - Precision Audio Control: Procedural Equalizer
The Procedural Equalizer is the most flexible tool in the MUSE (what is Muse) suite. It lets you build your own signal chain: a list of audio operations that run in the order you set, each applied only to the channels you choose. This is how you ...
Audio Analysis
What is Audio Analysis and how is it used? During Audio Analysis, your Roon Server scans each audio file in your library to extract waveform and loudness information. This data underpins several core Roon features: Volume Leveling Volume Leveling ...
