This article is for you if you run Roon Server on a NAS, an older Linux distribution, or a music server other than Nucleus or ROCK. You may have trouble with any of the following:
To fix this, you'll replace a file called bits in Roon's database folder on your server.
First, please find Roon's database folder on your server. We can't give exact steps for every device, because many different devices are affected. The folder is usually called RoonServer, and it always contains these subfolders: Cache, Database, Logs, Settings, and Temp.
If you run Roon Server on an older Linux variant, you can open its storage over your network, like a NAS. You'll need another computer on the same network. In the steps below, replace <ip-address> with your Roon Server device's local IP address.
\\<ip-address>\Data as the folder.guest for both.You should now see the RoonServer folder.
smb://<ip-address>/Data and click Connect.guest as both the name and password.You should now see the RoonServer folder.
guest doesn't work, please check your device's documentation for its file sharing username and password.If you run Roon Server on an Audioaanzee Reference Flow with Vortexbox, please follow the instructions shared by Roon Community users here.
bits file.bits file.
bits file or add a file extension to it. Roon won't recognize the file if its name changes.RoonServer folder, go to Database/Registry/Core.bits and delete it.bits file into Database/Registry/Core.If you still can't log in, search, add media, or reach your streaming services after replacing the bits file, please get in touch with our Technical Support team here. Please include your Roon Server device model and operating system.
