DSP Engine: Disabled During Zone Grouping
MUSE - Precision Audio Control: Disabled During Zone Grouping
Introduction
You've probably ended up on this page after seeing an error message similar to the one below:
This article provides more details regarding this limitation. This limitation only applies to zones that:
  1. Use AirPlay, Sonos, Squeezebox, KEF, Devialet AIR, or Meridian streaming technologies
  2. Have certain settings configured in MUSE
  3. Are participating in grouped playback
Why?
There's some extra technical complexity when performing grouped playback to zones with custom MUSE configurations. Combining these features requires Roon to send a different audio stream to each zone, and in some cases requires us to synchronize playback between streams playing at different sampling rates.
In some cases, the relevant playback technologies simply don't support these concepts and could not be made. In other cases, they are theoretically possible, but the effort that would be required hasn't been justifiable. Roon supports these use cases fully for situations involving RAAT, as it was designed from the start with considerations like this in mind. It's possible that we'll be able to deliver this functionality to some of the other technologies in the future, but this is not currently on our roadmap.
    • Related Articles
    • MUSE - Precision Audio Control: Headroom Management
      Introduction Headroom Management is part of the MUSE suite. For more information on accessing MUSE, see here. Digital signal processing can result in "clipping", or audio samples that exceed the allowed range. These samples are "clipped" to a maximum ...
      DSP Engine gives you tools that can create loud or potentially damaging sounds. Experiment at low volume levels until you are confident that things are all right. If in doubt, ask for help. Getting Started Each zone has its own, independently ...
    • MUSE - Precision Audio Control: Audeze Presets
      Audeze Presets are part of Roon's MUSE suite. For more information on accessing MUSE, see here. Audeze Presets are not included in MUSE for ARC but can be approximated using EQ. What are Audeze Presets? Audeze presets apply carefully designed ...
    • MUSE - Precision Audio Control: Accessing the MUSE suite
      There are several ways to access the MUSE - Precision Audio Control suite. In Roon From your volume controls: By right-clicking or long-pressing the current zone icon: From Signal Path: Using a keyboard shortcut: Windows: Ctrl-/ Mac: Command-/ In ARC ...
    • MUSE - Precision Audio Control: Parametric Equalizer
      Introduction The Parametric Equalizer is part of the MUSE suite. For more information on accessing MUSE, see here. Each MUSE configuration comes with a Parametric Equalizer by default. You can configure multiple equalizers if desired using the "Add ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
