MUSE DSP Engine: Speaker Setup
MUSE - Precision Audio Control: Speaker Setup
Speaker Setup is part of the [[DSP Engine. For more information on accessing the DSP Engine, [[see here|DSP Engine: Accessing DSP Engine]].
Speaker setup helps correct for inconsistencies in speaker placement or sensitivity.
For example, if the speakers are not equal distances from the listener, the soundstage may not be perceived as "centered". A distance adjustment can help. Gain adjustments are most frequently used when speakers or amplifiers don't match. This is common in multi-channel setups, where the front speakers are often much larger than the surround speakers.
When using speaker setup, start by measuring and setting the distance to each speaker, then use an SPL meter or calibrated microphone to measure the loudness at the listening point. Finally, adjust the gain to compensate for loudness differences and then measure again to ensure that you're getting a consistent result.
If an individual speaker, or your whole system, is wired backward, the invert phase settings are used to compensate.
Distance adjustments and phase reversal are both performed in a bit-perfect fashion. For more powerful room correction tools, you may want to check out [[Parametric Equalizer|DSP Engine: Parametric Equalizer]], [[Procedural Equalizer|DSP Engine: Procedural Equalizer]] and [[Convolution|DSP Engine: Convolution]].
