Amazon Eero is a popular WiFi mesh network bundle consisting of a main router and multiple nodes to expand the signal range. Roon users should take care to verify the following settings and conditions with their Eero networks to make the most of their Roon ecosystem and prevent networking issues.
Try rebooting the Eero router
Rebooting will automatically update any outdated firmware and refresh conditions across the network.
Verify your IP Address Allocation
Eero uses the subnet mask 255.255.252.0 to support multiple IP addresses, covering four Class C blocks (192.168.4.x - 192.168.7.x), ensuring devices in this range can communicate.
To limit Eero to a single Class C block to ensure traffic passes reliably between RoonServer, remotes, any networked endpoints.
- Go to Settings
- Select Network Settings
- Tap DHCP & NAT (under Network Services)
- Choose Manual IP
- Set the IP Address Prefix (for instance: 192.168.0.0)
- Enter your Subnet IP (for instance: 192.168.4.0)
- Set the Subnet Mask to 255.255.255.0
- Define the IP Range (for instance: 192.168.4.2 to 192.168.4.254)
The Eero will restart after saving these settings.
Connect your RoonServer machine to the main router with Ethernet
If your RoonServer machine is relying on WiFi or connected to a network node, consider rearranging your setup to connect with ethernet to your main Eero router instead. With RoonServer hardwired to the main router via ethernet, you've eliminated WiFi interference with Roon's main connection to the internet.
Verify Line-of-Sight Between Nodes
Eero nodes don't require a clear line-of-sight to connect to one another, but it can help reduce the impact of WiFi interference on Roon. Try placing Eero nodes high up, and if possible, try to strategically bypass any metal, cement, or reinforced walls through which a WiFi signal might have to pass.
Try temporarily switching off the 5.0 GHz band
Users can temporarily disable the 5 GHz band on their eero network for 10 minutes to help set up 2.4 GHz devices.
- Open the eero app
- Go to Settings
- Tap Troubleshooting -> My device won't connect
- Tap Temporarily pause 5 GHz
- Restart RoonServer, Remotes, and endpoints
