Using Focus
In Roon, you can filter your collection in all sorts of ways with Focus, which is available in the Albums, Tracks, Artists, Composers, and Compositions views.
For example, you can focus on Blues from the '60s and '70s.
You could also add the MP3 format, and click it a 2nd time to exclude MP3s.
This is what it looks like when you're focused on Pop/Rock albums from the '60s and '70s, excluding Singles:
Saving Focuses
If you create a Focus you love, or if you have certain views you want to come back to frequently, you can always save the current view by clicking the Bookmark icon in the upper-right, next to the search icon:
Click the bookmark icon, then click Add bookmark to save the current view.
Then, you can click the bookmark name to access it, or you can click Manage bookmarks to reorder, rename, or delete your Bookmarks.
Examples
You can create Bookmarks on nearly every screen in Roon. A few examples you might try are:
- High-resolution content
- Music From The Sixties
- Jazz, Sorted By Date
- All Albums Sorted By Import Date
- My Top 50 Most Played Albums
- Album Favorites (Sorted By Most Played)
- Albums I've Never Listened To
- Favorite Tracks Played This Week
Using Bookmarks and Saved Focuses
Once you've saved some bookmarks, you can access them from the bookmarks menu at any time.
When you load a saved focus you want to listen to, click the arrow next to
Play now and choose
Shuffle, and off you go! To learn more about how Shuffle works, see
Shuffle in Roon and Roon ARC.
Related Articles
Playlist Improver
What is the Playlist Improver? Playlist Improver helps keep your playlists in shape by finding tracks that can be updated, repaired, or optimized. When you open a playlist, Roon automatically scans its contents and identifies tracks that could ...
Smart Downloads
What is Smart Downloads? Smart Downloads (SDL) is a feature that automatically downloads your favorite music to your phone, so it’s ready on your device for offline listening whenever you want it. SDL takes into account your listening habits, ...
FAQ: I only want to browse albums in my collection from a certain decade, is there a way to do this?
Yes! Focus is what you're looking for. From the Album Browser, click the Focus button, then click anywhere on the Years graph. This will bring up a popup where you can select a decade, or drag the sliders to focus on a custom range of years.
Artists
The Artist Browser You can access the Artist Browser by clicking the navigation icon , then Artists. You will see the artists in your library displayed in a screen something like this: We've highlighted a few items (in red) in this screenshot for ...
Importing Playlists
Importing playlists is easy in Roon! In most cases it happens automatically as long as you have your storage set up correctly. Playlists imported from Tidal, iTunes, or from M3U files are not editable in Roon at this time. If you want to edit them in ...
