Roon now supports streaming to Logitech Squeezebox devices! Read on to get started!
Getting Started
Step 1: The first thing you should do is turn off any LMS servers running on your network. Roon's Squeezebox functionality works by emulating LMS--if LMS is running on your network, devices may find and associate with it, or become confused.
Step 2: To set up Roon to work with Squeezebox, you'll need to turn on Roon's Squeezebox functionality.
- Visit Settings, then select the Setup tab
- Click yes next to Enable Squeezebox Support:
Step 3: Once Squeezebox Support is turned on, you'll be able to see your Squeezebox devices in the Audio tab of Settings. Enable the device you want Roon to stream to. You can also click the small Gear icon to configure settings for your devices once they've been enabled.
Step 4: Once devices have been enabled, select then select them from the Zones menu, and Enjoy!
Troubleshooting Device Discovery
- Try power cycling the Squeezebox endpoints. We've noticed that some endpoints have trouble switching from LMS to Roon, particularly if LMS was running at the same machine as the Roon Server.
- If that doesn't help, verify that the firewall settings on the machine running your Roon Core allow incoming connections.
- If that doesn't help, try typing in the IP address of your Roon server as a workaround.
- If that doesn't work, let us know.
mysqueezebox.com
It is possible to use Roon alongside mysqueezebox.com. This provides a workaround for obtaining alarm or radio functionality that Roon does not currently provide.
When an endpoint is in "Roon Mode", you can switch to mysqueezebox.com by pressing the "+" button on the front panel or remote (for devices with blue vacuum fluorescent displays), or via the settings screens (for devices with LCDs). You can switch back to Roon using the pre-existing mechanism.
Display preferences + Brightness (VFD devices only)
Note that Roon is unable to render fonts on VFD devices, but we do support display of a Roon logo + any visualizers supported by your device.
You can cycle through display options and brightness settings using the "Display" and "Brightness" buttons on your remote control. You can also make selections in Roon's Audio Settings for the device:
Notes on Squeezebox Touch with EDO
Roon supports the EDO plugin available for the Squeezebox Touch. You must have a 7.8.x firmware version installed on your Touch in order to take advantage of EDO with Roon.
If you have connected a DoP capable DAC to your Squeezebox Touch+EDO, you can instruct Roon to send DSD content using DoP instead of converting it to PCM. This allows for bit-perfect DSD playback.
Squeezelite/Software endpoints: Roon does not support software implementations of squeezebox endpoints, and we do not test with them as part of our QA process. If you attempt to do this, you are on your own.
Related Articles
FAQ: How do I use Roon with Airplay devices?
Start by clicking the Zone icon in the bottom-right (next to volume): You'll see a link to Audio Setup. You can also access your audio configuration in Settings, under the Audio tab. In Audio Setup, you'll see a section called Networked -- if you're ...
FAQ: What audio outputs or devices are supported by Roon?
Connected Outputs: Built-in outputs, USB DACs, and Sound Cards Any audio devices recognized by the OS will be recognized by Roon, from Built-in Sound to PCI Soundcards to USB DACs. In the settings of Roon, you will select which recognized audio ...
FAQ: What Android devices can I use Roon with?
Roon can run on many Android devices that meet the following requirements: ARM or x86 based Android 5.0 or higher Supports OpenGL ES 3.0 Android devices that are at least 8 inches run the full Roon interface. Tablets smaller than 8 inches run an ...
Squeezebox Setup
Getting Started Step 1: The first thing you should do is turn off any Logitech Media Server (LMS) instances running on your network. Roon's Squeezebox functionality works by emulating LMS--if LMS is running on your network, devices may find and ...
FAQ: Can I control Roon remotely?
When you first install Roon, you will set up your Core, which functions as the main server for Roon in your household. Whether your Core is near where you listen to music or on the other side of the house, there's a good chance it's not a convenient ...
