FAQ: I'm having problems setting up Airplay
Airplay Setup & Troubleshooting
I'm having problems with Airplay -- help!
Setup
To use an Airplay device with Roon, first make sure Roon is running on the same network as the Airplay device. If you are running supported Airplay devices on the same network, they should appear on the Audio tab of Settings, like this:
Once you've enabled an Airplay device, it should appear in the zones menu, something like this:
Select your Airplay zone, pick something to listen to, and press play. That's it!
Apple TV
A) Open settings on the AppleTV
B) Navigate to AirPlay and Homekit
C) Tap on “Allow Access”
D) Set “Allow Access” to “Anyone on the Same Network”
E) Set Require Password to “On” and create a password
D) Back out of the menu to the home screen
F) Try to enable the zone in Roon. It should ask you for the password
Troubleshooting
Update Your Firmware
If you're having problems with Airplay, the first thing you should do is consult your manufacturer to see if updated firmware is available. Certain devices (particularly those that predate 2011) may be using older versions of Airplay, so it's worth looking into updated firmware if it's available.
Confirm Your Security Settings
Some devices, such as AppleTV, may have security settings that prevent Roon from streaming. Check your manual or consult your device's manufacturer for more information. On AppleTV, the setting was introduced in Apple TV software version 6.1. To disable it, go to Settings > AirPlay > Security > Require Device Verification and set verification to off.
Check Your Network
Some Airplay issues are caused by network issues, and the simplest way to solve these issues is to, uh, simplify your setup. For example, if your network involves multiple routers, bridges, EoP, etc, spread across a large house, you might try plugging everything into the router directly and seeing if things are resolved with a simpler setup.
Still stuck?
Let us know in the Support forum. We're ready to help!
    • Related Articles
    • AirPlay Setup
      AirPlay Roon has excellent support for most AirPlay devices out there. Sometimes small adjustments may be needed to cope with new devices as they reach the market. If you're having trouble with a particular AirPlay device, take a look at our ...
    • FAQ: Which zones can I control remotely?
      What kinds of outputs can I control remotely in Roon? You can use Roon to remotely control anyzone, including: Outputs connected to your Roon Server Outputs connected to devices or computers that are running Roon as a remote Outputs connected to ...
    • FAQ: Why did all my zones disappear?
      If your zones are not showing up in Roon, or all of your audio outputs are gone, it typically indicates: A networking problem is interfering with Roon's ability to communicate with your zones. Review our network best practices for tips on ensuring ...
    • FAQ: What's Exclusive Mode?
      Exclusive mode allows Roon to take full control of the audio device when music is playing, bypassing the operating system mixer (on your desktop or laptop computer) and interrupting any other applications using the device. Running with Exclusive mode ...
    • FAQ: Setting Up Roon on MacOS
      Roon is a powerful music management and playback platform that works beautifully on macOS. There are a few important things to know before you dive in and this guide will do just that: it will walk you through the essentials for setting up Roon on ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
