Reset network settings on RoonOS
If you've set a static IP address on a Nucleus or ROCK and can no longer reach it on your network, you can reset its network settings. This puts the device back on DHCP, so your router gives it a new address automatically.
Info
This only resets your network settings. Your Roon library, settings, and music aren't affected.
Before You Begin
  • A TV or monitor with an HDMI input, and an HDMI cable.
  • A USB keyboard.
On RoonOS 3.0, the TV also shows a diagnostics screen with your device's IP address while it starts up. If your device is still reachable at that address, you may not need to reset anything. Please try that address in a web browser first.
Reset the Network Settings
  1. Connect your Nucleus or ROCK to a TV or monitor over HDMI.
  2. Connect a USB keyboard to your Nucleus or ROCK.
  3. On RoonOS 3.0, if the screen shows the Roon logo or Now Playing, press Esc to leave the display and show the console.
  4. Press Enter.
  5. Type resetnetwork, then press Enter.
Your device's network settings are now reset to DHCP.
Reconnect to Your Device
  1. In Roon, go to Settings > Setup, then click Find next to Find Roon OS.
  2. Click your device's new IP address to open the Web Administration Interface for your Nucleus or ROCK.
  3. If you still want a fixed address, please set it again under Networking. On RoonOS 3.0, you'll find it on the Network & Access tab.
Notes
To avoid this in the future, please make sure a static IP address is in your router's range and isn't used by another device. Alternatively, keep your device on DHCP and set up an address reservation on your router.
Still can't reach your Nucleus or ROCK after resetting its network settings? Please get in touch with our Technical Support team here.
    • Related Articles
    • Nucleus Web Administration Interface
      What is the Web Administration Interface The Nucleus Web Administration Interface (the "Web UI" for short) lets you manage your Nucleus at the system level from any web browser on your network. You can check its status, update or reinstall its ...
    • Nucleus Internal Storage
      Your Nucleus supports an internal 2.5" HDD or SSD, turning it into a self-contained music server. For a completely silent system, we recommend an SSD. RoonOS uses the entire drive for music, and you can create subfolders on it later over the network. ...
    • ROCK: RoonOS Web Administration Interface
      What is the Web Administration Interface The RoonOS Web Administration Interface (the "Web UI" for short) is a built-in control panel for your ROCK. You can open it from any web browser on your network. You can check its status, update or reinstall ...
    • Reset Roon Database on Mac/Windows
      This article covers three different resets. The first refreshes the Roon app's database on your Windows or Mac computer, without touching Roon Server. The second resets the Roon Server database when Roon Server runs on a Windows or Mac computer. The ...
    • Roon Optimized Core Kit
      Roon Optimized Core Kit (ROCK) lets you build your own Roon Server appliance on an Intel NUC. This article explains what RoonOS and ROCK are, which hardware ROCK supports, and how to get the installer. RoonOS 3.0 comes to ROCK installed in UEFI mode ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
