Overview
Issue: Roon storage drive disappears after installing the MacOS Ventura update
If you are using Roon on MacOS as your server and have updated to macOS Ventura, please be aware that the way MacOS sees an exFAT formatted HDD or USB drive has changed, and that storage drives will not appear properly in Roon.
Steps to resolve:
1. Go to Settings -> Storage with your Mac set as your server and select “Add folder”.
2. Click your HD (it will be named) to the left.
3. Select volumes from the list on the right. If you don’t have this option, click your HDD on the left again, and the list will refresh.
4. You will get the following warning when you click volumes:
