Smart Downloads
Smart Downloads
What is Smart Downloads?
Smart Downloads (SDL) is a feature that automatically downloads your favorite music to your phone, so it’s ready on your device for offline listening whenever you want it. SDL takes into account your listening habits, history, favorites, and recent activity to determine the music you like the most. The more you listen, add, and favorite, the better your Smart Downloads will be.
Who is it for?
ARC users who:
  • Have local files
  • Want to let ARC handle your download logistics
  • Go offline often
  • Want to save data by listening to downloaded files
  • Want to easily download their entire library
Notes
Smart Downloads is only available for ARC users who have local files on their Roon Server. Due to licensing restrictions ARC does not allow for downloading music from streaming partners.
Getting Started
Enabling Smart Downloads
In order to enable Smart Downloads, ensure that you:
  1. Have more than 20% charge on your phone
  2. Are on WiFi
  3. Have ARC open and your phone unlocked
To enable Smart Downloads, go to the downloads browser and navigate to the SDL page.
From there, you can enable SDL by selecting the chunky enable button in the top box.
Once it’s on, you can toggle it on or off via the switch in the top right.
Smart Downloads Page
The Smart Downloads page is broken up into three sections.
Here's what they mean:
Status
This section tells you the status of your Smart Downloads. Once enabled, there are four statuses:
  • All Set - SDL is enabled and activated
  • Downloading - SDL are actively downloading
  • Paused - SDL is paused. Normal downloads can still continue
  • Disabled - SDL is not on
Storage
This section shows you how much storage you’ve allotted to smart downloads. You can move the slider to set the amount of storage space you’ll give smart downloads.
So you gave SDL some space. Now, in order to know how much music this is, you must take into account the quality setting below. 5GB at CD quality is much less than 5GB at bandwidth optimized. The blurbs in this section use help put these values into more relatable terms, we think!
Quality
SDL supports multiple download quality settings, ranging from quality-hungry original format to economical bandwidth-optimized. The settings are identical to those in the “streaming quality” section.
Notes
This slider affects the quality of all downloads in ARC, smart or manual. In other words, if you adjust this setting to “bandwidth optimized” and download your whole library elsewhere, it will be downloaded in bandwidth optimized. Conversely, if you go to settings and adjust your download quality setting to “CD Quality” your new Smart Downloads will now be in CD Quality. Both points of access control the same underlying setting.
Downloads Browser
On the downloads browser, you will see Smart Downloads items demarcated by the SDL icon (magenta lightning bolt). Be on the lookout for this, whenever you see it, this item is a smart download. Manual downloads will still have the normal purple checkmark. When Smart Downloads are active, the SDL icon will light up and pulse 👀
On the downloads browser, you will see a filter section in the top left, you can use this to filter by:
  1. All downloads
  2. Your downloads (manual downloads)
  3. Smart downloads
  4. Queued downloads
FAQ
Do Smart Downloads work in the background?
Android: On Android devices, SDL operates seamlessly in the background, allowing you to use your device without interrupting the download process.
iOS: Due to iOS's unique handling of background tasks, SDL operates at a reduced speed when ARC is not in the foreground.
Notes
For best results on both platforms, it is recommended to keep ARC open and in the foreground.
Are my Smart Downloads static? Does it swap things out?
Smart Downloads are ephemeral. SDLs takes the space you give it and fills it in with your favorite music, so it’s there when you need it. As your listening patterns change, SDL may remove or add content to ensure it’s constantly fresh and interesting to you. As you add, favorite, listen or remove music from your library—SDL’s concept of “your favorite music” is constantly evolving.
SDL downloaded some good stuff. How can I keep it? Actually… how can I remove it?
If you want save a smart downloaded item, you can “keep” it. This essentially elevates the downloaded thing to a “normal” download, which won’t get deleted willy-nilly. To “keep” an item, just click on the download icon to open the download-specific menu. From there you can select “keep in downloads.”
Conversely, removing things you don’t like will only help SDL to get better at knowing your taste. Within that same menu you can also select “remove smart download.”
Can I pause Smart Downloads?
Yep, you can. Just tap on the play/pause icon on the SDL page whenever SDL are actively downloading.
If downloads have been globally paused, SDL are paused as well. However, if you have paused SDL, that only affects SDL. Manual downloads can still come through.
  • All downloads [Pause/Unpaused]
    • Smart Downloads [Paused/Unpaused]
When does SDL rotate content?
Smart Downloads checks for new content from your Roon Server frequently. If there are enough valuable things on the Server side, Smart Downloads will rotate your downloads. Depending on storage availability, this may mean removing things you might not like (e.g. things you didn’t listen to) and adding things you might like (e.g. a recently added album).
The best way to ensure you have everything you like is to favorite, play, or “keep” downloads you want to save.
Please note that if you’ve already downloaded all of your available content via SDL, there will be no rotation as there’s nothing to rotate in.
What happens when I disable Smart Downloads?
Disabling Smart Downloads both turns off the feature and deletes any existing SDL content. If you have SDL content you’d like to keep, be sure to “keep” your downloads before you disable the feature.
Why isn’t Smart Downloads starting?
As a first port of call, ensure that you:
  1. Are on WiFi
  2. Have SDL enabled
  3. Have local files eligible for download
  4. Have more than 20% battery
If it is not starting, ask these additional questions:
  • Is SDL already full?
  • Do I have more content on my Roon Server that could be downloaded?
  • Is my phone out of storage? (check your settings screen or look for an error at the top of the SDL page).
If you determine that SDL, despite having the right conditions, is not fetching your music, try these fixes:
  • Restart ARC
  • Adjust your storage setting
  • Restart your Roon Server
Notes
Even when it’s enabled, SDL shouldn’t be running all the time. Sometimes it may determine there’s nothing valuable enough to download or it may be between checks with the Roon Server.
I want downloads… but less smart
ARC also offers plain old regular downloads. You can download things one at a time via the context menu on an album or a playlist, or you can download a big list of things all at once via the “download all” function in the context menu.
Having trouble with SDL? Get in touch with our Technical Support over on the
Roon Community
The team at Roon Labs
    • Related Articles
    • Offline Listening in Roon ARC
      To begin make sure you have Roon ARC installed on your mobile device In this how-to, we’ll walk you through everything you need to know to listen offline in ARC. First, you’ll need to make sure you’ve installed Roon ARC on your mobile device. Visit ...
    • Windows 11 Smart App Control Can Block Roon
      Overview Smart App Control is a security feature enabled by default on new, off-the-shelf Windows 11 installs. When active, it can prevent RoonServer from accessing the network, causing connectivity issues with your Roon Remotes and Zones. This issue ...
    • Focus
      Using Focus In Roon, you can filter your collection in all sorts of ways with Focus, which is available in the Albums, Tracks, Artists, Composers, and Compositions views. For example, you can focus on Blues from the '60s and '70s. You could also add ...
    • Software packages
      Roon is offered in a variety of software packages to accommodate your setup. Whether you are running Roon on a single computer or need to stream audio to multiple rooms across several devices, you can use this overview to find the right version of ...
    • Troubleshooting "There Was an Issue Loading Your Database"
      These symptoms typically occur when your Roon database can't be read properly by Roon. First, try giving your server machine a reboot, many times this will resolve the issue. If that doesn't help, it might be a sign that your database has become ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
