Adding Local Folders By + New Folder
Finding Your Music Folder in Roon's Storage Settings
When you add a Watched Folder, Roon opens its folder browser so you can navigate to where your music lives. This article explains how to find and select your existing music folder in that browser, and what the New folder button actually does.
Info
This article covers navigating the folder browser. For everything about adding music to Roon, including network shares, path formats, and NAS setup, see Adding Local Music to Roon.
The Folder Browser at a Glance
Open Settings, then Storage, then click + Add folder. The Choose music storage folder browser opens. It has three parts:
  • The left pane lists the storage Roon Server can see: drives attached to the server machine, and any network shares you've added.
  • The Folder listing on the right shows the folders inside whatever you've selected on the left.
  • The Selected folder breadcrumb at the top shows where you are right now.
Finding Your Existing Music Folder
  1. In the left pane, select the drive or share where your music is stored.
  2. In the Folder listing, click a folder to open it and see the folders inside.
  3. To go back up a level, click the up arrow at the top right of the Folder listing. To reload the listing, click the refresh arrow beside it.
  4. When the Selected folder breadcrumb shows the folder you want Roon to watch, click Select this folder.
Roon watches everything inside the folder you select, including its subfolders. You don't need to drill into the deepest folder; select the top-level music folder instead.
What the New Folder Button Does
New folder creates a new, empty folder inside your current location. Clicking it asks for one thing only: a name ("Please enter the name of the folder you wish to create"). It doesn't open a folder, it doesn't accept a path, and it won't help you navigate to music you already have. To add an existing music folder, browse to it and click Select this folder as described above.
New folder is useful when you want a fresh destination for music, for example, creating a Music folder on your Nucleus's internal drive before copying files to it over your network. For that workflow, see Nucleus internal storage.
If Your Folder Isn't Listed
  • The drive isn't attached to the server machine. The browser shows storage as Roon Server sees it, not as your remote device sees it. Music on another computer or a NAS must be added as a network share; see Adding Local Music to Roon.
  • You just plugged the drive in. Click the refresh arrow in the Folder listing.
  • You're not sure what a Watched Folder is. See What's a watched folder?
If you've browsed to where your music should be and it still isn't showing, please get in touch with our Technical Support team here and include the device running Roon Server, where the music is stored, and what the browser shows.
    • Related Articles
    • Adding Local Music to Roon
      If you added your music during setup, you're all set. This article covers adding music afterward: copying files into Roon, watching a folder on your server, and adding music from a NAS or another computer. Copy Music into Roon The simplest way to add ...
    • FAQ: How do I set up Roon to import from my NAS?
      In Settings, click Storage, then click Add Folder to display the Choose Music Storage Folder dialog... Roon will monitor folders for new music. Your files are left in the folder and won't be copied or modified in any way unless you explicitly choose ...
    • Storage
      Overview In Roon, Storage refers to the location(s) of your local library. Below, you will find a handful of popular storage locations along with their descriptions. Local Folders On first launch, Roon will find the default music folder on your ...
    • Roon Server on NAS
      Roon Server requires a more powerful processor than most media servers due to our architecture. Historically, most NAS devices have not been powerful enough to deliver a first-class experience with Roon, but an increasing number are becoming capable. ...
    • Nucleus Internal Storage
      Your Nucleus supports an internal 2.5" HDD or SSD to create a self-contained music server. For a completely silent system, we recommend using an SSD. If you chose to use an SSD here, the system will stay fully silent. The entire internal storage ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
