Roon Supported Audio Devices
FAQ: What audio outputs or devices are supported by Roon?
Connected Outputs: Built-in outputs, USB DACs, and Sound Cards
Any audio devices recognized by the OS running Roon or Roon Server will be recognized by Roon, from Built-in Sound to PCI Soundcards to USB DACs. In the settings of Roon under the Audio tab, you can see and select which recognized audio devices you would like to display as Zones for playback in Roon. Any Zone can also be configured to support Exclusive (bit-perfect) mode. Playback to these devices uses Roon's RAAT technology, and can be grouped with each other or other RAAT-based zones for multi-zone playback.
Roon Ready & Roon Tested Devices
Roon Ready and Roon Tested devices are supported and can be grouped with other Roon Ready and Roon Tested devices for synchronized playback.  For the latest list of Roon Ready and Roon Tested devices please see our Partners Page.
Apple Airplay
Any Airplay devices on the same network as your Roon devices, whether Apple or third-party Airplay, will be recognized by Roon. In the settings of Roon, you will select which recognized Airplay devices you would like to display as Zones in Roon. Airplay devices can be grouped with other Airplay devices for multi-zone synchronized playback.
It should be noted that:
  1. Software Airplay "servers" are sometimes unreliable with Roon
  2. The Airplay protocol can only play at 44.1khz/16bit (Roon will downsample higher-resolution content when played to Airplay zones)
For more information on setting up AirPlay devices, see AirPlay Setup.
Sonos
Roon should work with all Sonos hardware. To learn more about using Sonos in Roon, visit our Sonos documentation.
Logitech Squeezebox
Squeezebox endpoints are supported. For more information on setting up Squeezebox devices, see Squeezebox Setup.
Meridian Audio
Many Meridian Audio devices will be discovered by Roon and can be enabled for usage. Meridian Audio endpoints can be grouped with other Meridian Audio endpoints for multi-room synchronized playback. For more information on setting up Meridian devices, see Meridian Setup.
Chromecast
Chromecast is fully supported by Roon. See Chromecast for more information.
HQPlayer
Roon can stream directly to HQPlayer, whether both applications are running on the same machine or if they're on different machines on your network.
Devialet
Roon includes built-in support for the Devialet AIR protocol, used by Devialet's Expert and Expert Pro devices. This is a new implementation of AIR, undertaken at Roon Labs. It does not require Devialet's AIR driver, and works with Roon Servers running on any platform.
Not seeing your device? Search from our full partner list here.
    • Related Articles
    • FAQ: Setting Up Roon on MacOS
      Roon is a powerful music management and playback platform that works beautifully on macOS. There are a few important things to know before you dive in and this guide will do just that: it will walk you through the essentials for setting up Roon on ...
    • Fix Missing Audio Devices After a macOS Update in Roon
      If your audio devices disappeared from Roon after a macOS update, this article walks you through the steps that can help restore them. Try each section in order. If your devices return, you can stop there. Otherwise, move on to the next section. ...
    • Nucleus Media Storage And Audio Devices
      Roon can watch multiple storage locations at the same time, so you can use any or all of the options below together. This article also covers the ways you can connect audio devices to your Nucleus. Some features below, such as Check & repair and the ...
    • Audio Setup Basics
      Accessing Audio Settings To access audio settings, click the settings cogwheel from the navigation bar, then choose the Audio tab. Inside the Audio tab, you'll be presented with a list of audio output devices, grouped by type, and in some cases, by ...
    • Roon Hardware Specification Recommendations
      Roon will run on just about any recent PC or Mac. Performance and quality of experience will depend on the size of your music collection and the performance of your hardware. Check out this comment on our community site for the nitty gritty details. ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
