FAQ: How can I ensure multi disc sets and box sets are identified properly?
If you’re importing a multi-disc set, the best way to ensure it’s identified properly is to make sure the track listing matches the original release.
Identifying Multi-Disc Sets
For best results, make sure the whole set is in its own folder, and make sure the file tags include:
  1. The name of the album (meaning all discs have the same album title)
  2. Accurate track numbers, (meaning each disc starts with Track 1)
  3. Accurate media numbers (meaning each disc is numbered Disc X of Y, with Y being the total number of discs in the set)
Directories
We look for a couple of different possible folder structures when it comes to the individual discs. So this scheme will work:
Music/
    Miles Davis - The Complete Columbia Album Collection/
        01-01 Track.flac
        01-02 Track.flac
        02-01 Track.flac
        02-02 Track.flac
    Pink Floyd: Discovery/
        01-01 Track.flac
        01-02 Track.flac
        02-01 Track.flac
        02-02 Track.flac
And this will work just as well:
Music/
        CD1/
            01 Track.flac
            02 Track.flac
        CD2/
            01 Track.flac
            02 Track.flac
        CD1/
            01 Track.flac
            02 Track.flac
        CD2/
            01 Track.flac
            02 Track.flac
One thing that likely won't work is having all the discs of a box set separated into album-level directories, like this:
Music/
    Miles Davis - The Complete Columbia Album Collection CD1/
        01-01 Track.flac
        01-02 Track.flac
    Miles Davis - The Complete Columbia Album Collection CD2/
        02-01 Track.flac
        02-02 Track.flac
    Pink Floyd: Discovery CD1/
        01-01 Track.flac
        01-02 Track.flac
    Pink Floyd: Discovery CD2/
        02-01 Track.flac
        02-02 Track.flac
Don't do that!
Fixing Errors
If a set you've imported doesn't seem to be identifying properly, you can edit your files directly, or you can edit the album in Roon. If your set is split up, you can select the various discs in the album browser, and then choose Merge to combine them into a single disc.
You can also select the disc (or click Edit under the 3 dots menu while viewing its Album Details screen) and choose Identify, to search Roon's database and try to find a better match.
    • Related Articles
    • FAQ: Some characters are not displaying properly
      File Tag Encoding and Display Issues If some characters are not displaying properly in Roon, it's possible your file tags are using an outdated encoding scheme, and need to be encoded in Unicode/utf8.   Example of tags that do not use Unicode  ...
    • FAQ: How can I tell if Roon has identified my album?
      If Roon has failed to match your album automatically, you'll see the word Unidentified on the album's detail page, like this: Searching For a Match To search for a match, start by clicking Unidentified. If you're trying to improve or correct an ...
    • Editing and Grooming Your Collection
      Even prior to our launch in May '15, it was clear Roon needed to do much more to meet the needs of users who want to exert control over how metadata is displayed and experienced in the app. At launch, Roon was focused on the user who wants their ...
    • FAQ: An album I imported wasn't identified properly, how do I fix it?
      Roon will always try to find the best match for the albums in your collection. However, if you're not happy with the information we've retrieved, we've made it easy for you to correct it. To try and find a better match, click the 3 dot icon on the ...
    • FAQ:How can I find tracks by path?
      If you need to find a track using a path, you can do that from the Tracks browser. Finding A Track By Path Start by navigating to the Tracks browser, and enabling the Paths column, like this: Then you can use the Filter feature at the top of the ...
    Visit the Roon Community!
    Need help? Thousands of Roon subscribers and audio enthusiasts are chatting over on our community site right now, join them! You don't even need a Roon subscription to sign up.
